Remove m490 Nokia amp
Hope that some knows the answer to this, just found out that i only have the m490 4 channel amp, and i bought rear speakers, but i am not able to hear them as my amp (standard nokia) does not have the connection.. what i want to try is revert back from the amp and hook up all the speakers to my becker cascade pro .. anyone done this? where are the speaker cables? dont seem to find any, all wires go to the amp or do i need to cut the and rout them back??
Options - suggestions - other advice why don't or do it are very welcome ..
I'm not familiar with the Becker Cascade so my experience may not be relevant to your situation.
When I installed the rear speakers on my 2000, I was able to wire the speakers to the head unit (Becker CDR-220) and avoid changing the wiring for the other speakers. I later purchased a used six-channel amplifier from a 996 cabriolet which permits me to power all six speakers from the amp. The M680 needs only minor modification when used to replace the M490.
The sound quality is slightly better using the amp instead of the head unit.
I believe that if you decide to use an after-market amp that the most convenient method would be to use the speaker wires that run to the existing amp. This post has the wiring diagram:
Good luck with your project.
[/quote}
Thanks but that is what i currently have installed, the problem is even when i do the fader on the back speakers and turn it full up i hear a high tones and very soft music . looks like i didn't hook something up then correctly.. (although i did use the right ports on the cascade ) ... * puzzled *
Edited by sliderr
Connection for the rear speaker kit is very straight forward. Green/Black (rear right positive) wire goes into position number 1 on the brown plug and it's negative into position 2. Red/Black (rear left positive) wires goes into position 7 and it's negative goes into position 8. Also, when you fade to the back you won't get the full compliment of sounds, basically voices from the rear speakers, bass from the door speakers and most music from the front speakers.
