Hi All
ok i need a new oil pump in the gearbox, and have found a company who are going to do this for me.
does anyone know if anything (computer) related has to be done when the gearbox is re connected.
i have been told that the computer for the gear selection has to be re trained or something like that??
i just need to know if the car will have to be sent to porsche once the work is complete
thanks in advance
The transmission control unit should not be effected since the pump seal it not really part of the geartrain itself. Its the seal right not the pump itself, that would be VERY unusual
No adaptions needed. The transmission will relearn as you drive if there are no fault codes stored in the system.
