1999 C2 -DME 5.2 .Has anyone done a test( with the Durametric Software) of the camshaft deviation to verify that the actuators are kicking in ?I am flatlined at 3 degrees .The drive link function is working and no cel .I have tried all reasonable rpm ranges and the reading doesn't change .It's either the software or I have a problem .
Easy to eliminate the software if someone else has sucessfully done the test with the 5.2 DME.Thank you
Dave
