Loss of 2nd and 4th Gear
I recently lost 2nd and 4th gear in MY98 Boxster. Before removing the center console to check the shifting cables attachments to the shifter I decided to first check the cables at the transmission end. I just drove up onto a few 2x6's and removed the metal aluminum plate located behind the passenger tire and between the muffler and catalytic converter. To remove the plate loosen the two 10mm nuts and remove. Here is what I saw. To repair: 1) Jack up the rear wheels with a hydraulic ja
