Hi, Just received the durametric cable and downloaded software ver 6. Ran the "test all modules" and received the following error.
353: Feedback from blower regulator front - Upper limit value exceeded, test conditions are not-completed, fault is not currently active and is not causing a DTC light
Any ideas?? Everything seems to be working OK, but is something looming on the horizon that needs to be addressee now?
It's an 04 cayenne S with an 4.5/V8
Thank You for your feedback.
Under what test chapter? sure it's 353, P0353 is Bar Ignition module, cilinder 3 (bank1)
