Stupidest idea ever? Or no big deal?
Getting the car up and down off the jackstands is a PITA.
I drained the cooling system as part of some projects I'm doing. So it's on the jackstands now.
But as I don't know what kind of coolant was in the car, I'm going to flush it with water, which means running the car. And then draining the system completely again before putting the final fill of 50/50 coolant in.
If it's safely on the stands and somewhat level it should be ok but I don't recommend running it through the gears while up on stands.
