CEL P1250 and P0301
So a while back I fixed a P0306 code by replacing the coil pack. Past couple days it's been insanely hot outside (100+). Yesterday while doing a WOT pull, another misfire code as well as a boost related code popped up P1250 and P0301. Are they related? Or should I just replace the coilpack again and see if it fixes the problems? I was checking the DV's and the vacuum hoses going to the wg's and no visible leaks. Will pick up a Mityvac tmrw and do a boost leak test. So do I just fit the rubber fitting into the WG connection and pump up the pressure or what? Sorry I'm a noob
