Hi guys,
Hopefully someone has had this problem before on their car which is, Transmission Emergency Run in red appears on instrument cluster and vehicle will be stuck in gear and unable to shift up or down.
Fault code retrieved from PIWIS Tester is P0841, Pressure Sensor 1 Measured Value Implausible. Fault Type: Signal Implausible. Heard its a common problem and replacing the valve body (Electrohydraulic Control Unit) will solve the problem??
Many Thanks,
Justin
Hi guys,
Many Thanks,
Justin
Are you still under warranty?
Afraid not bro..Its a grey market car..
Hi guys,
Many Thanks,
Justin
