Hi there,
I am trying to get my PST2 to connect to PCM2 on a Cayenne Turbo 2004. System seems to connect (PCM display shows "Service...") but then it disconnects.
It is an orioginal PST2 with v24.
Does anybody has an idea whats wrong?
Thanks Rene
What is the original problem with the PCM or is it working correctly? Are the connections at the rear of the unit secure?
hi, yes everthing is ok with pcm and connections on back. i just wanted to include a new cd-changer in most-bus (was not there before).
any ideas? thougt with pst2 pcm2 is no problem. everything else works, just this **** pcm not.
thanks
Hi, it is not the original. I just added a dension gateway. everything is working, bút sometimes it shows system failure.
But generaly I wanna know why PST2 has a problem with the PCM2 at all.
