I have a 2009 Cayenne Turbo S that I'm experiencing erratic performance with, that is, sometimes the acceleration is not what it should be.
When it's doing that, I also get the impression that the engine is lugging when running at relatively low speeds (50-60 mph) in 6th gear.
If I put it in "Sport" mode it seems to be behaving normally.
When I first got the car, the dealer discovered that it had been programmed ("flashed") as a Turbo instead of a Turbo S. That was thought
to be the culprit, but the problem still seems to occur.
Anybody have any experience with this?
thanks in advance
