oil leak at cam sensors
Unfortunately this is not an easy fix.
Passenger side: remove the air conditining compressor, remove the sensor, replace the o-ring, reinstall the sensor & A/C compressor.
Drivers side: unbolt the AOS so it can be moved out of the way (does not have to be removed), remove the sensor, replace the o-ring, reinstall the sensor & AOS.
Use a very small amount of tire grease on the new o-rings.
