I have a 2002 boxster s. unfortunately water got in to the car.
I change the alarm module. Took the car to dealer for programming.
Still can not get the car to start or crank. Check all the fuses.
Any help from any body
You've posted in the Cayenne section, you might get more responses in the 986 section.
The dealer didn't give advice as to what may the problem? Did the module programing go ok with no issues? I assume the battery has been tested.
Programming went okay.
I just found out the battery is not charging. I will change the battery this week
If the battery is not charging there will be done more than just replace the battery. I would urgently checked the charging system if i were you.
I change the battery but no luck
I can not even get the dash lights to come up.
I check all the fuses and they are good
Anybody with any ideas , I don't know where to start
It seems that the key codes are not transferred into the new alarm module, i understand from your post that the car was at the dealer for programming, they have no test done after programming? That sounds weird to me.
they got the programing done but the car still did not start. they siad $110 per hour to trouble shoot. they were not sure of the what is going on.
do you know where i can get the wiring digrams for this car.
may be i can start trouble shooting.
