Cylinder 5 Injector Circuit error
Hi, I would like to ask for some help regarding a code that the Durametric is showing. I already erased it a couple of times, and got it back within a week of use. You can sometimes feel like a "misfire" or hesitation when accelerated hard, but it is not always present.
U0D00
Cylinder 5 Injector Circuit - No signal/communication, test conditions are not-completed, fault is not currently active and is not causing a DTC light
What should I check / change?
