Another one:
I noticed the rubber seal that seals of the enginebay when the bonnet is closed doesn't seem to sit well...
It seems too short so if you tighten the fit at one end, the other end pulls out again and on top nearest the window I'm not sure if it should fit to the metal ledge or the metal ledge combined with the plastic cover adjacent to that...
I'm not quite sure how to explain, does anyone know what I mean?
Almost every cayenne I have seen has this problem, my own included. I removed it, soaked in hot water, stretched it gently and reinstalled. It fit correctly but only lasted a week or so before returning to it's original size.
