Tiptronic from Boxster S into a Boxster?
My saga of transmission problems in the Boxster knows no end....
1. Tiptronic case cracked 7 years ago -- complete rebuild
2. The rebuilder didn't block off some hole inside the new case, tiptronic fails 3 years later mysteriously -- complete rebuild
3. The new rebuilder didn't realise the hole was meant to be blocked (because he didn't have the original case to compare with) -- another rebuild by a 3rd rebuilder after I supplied the original case which I happened to have kept
4. Now, 4 years later, the tiptronic is leaking again, from the front.
The transmission guy is saying it's very unlikely to be seals, since it was only rebuilt 4 years ago. So maybe we are looking at another cracked case.
So, instead of getting a new case and do yet another rebuild, I am thinking about just buying a secondhand transmission and fit that instead.
My car is MY97, 2.5L engine.
My questions are:
1. up to what year will those transmissions fit into my MY97?
2. I assume the 2.7L cars will have the same transmissions?
3. What about the 3.2L s models? Can I fit that transmission without changing the tiptronic ECU?
Edited by Jinster
The Tiptronic themselves are basicaly the same but the ratios, gears and differential, are different by type of vehicle and model year, it is advisable to keep the same year and type of Tiptronic, otherwise it would be an experiment regarding accelerations/top speed/shift points/etc. The difference between Tiptronic and Tiptronic-S is the ECU and the buttons, not the Tiptronic itself.
