Hi, I have a 2003 Cayenne turbo. The rear passenger door will not lock when I use the fob or the keyless button on the external door handles. To get it to lock I have to remove the rubber grommet and manually move the lock override to lock the door. I suspect it is a faulty lock mechanism. The door clicks 2-3 times when grabbing the handle vs once for the rest of the doors and the underdoor light flashes. I looked up the part and noticed there are 3 versions of the lock.
Does my diagnosis sound accurate?
What are the differences in the 3 lock models (I4K3, I4K0, I4F2) and how do I know which one my car has?
Thanks in advance for your help!
Let us know what part your replaced, my 04 has been doing the same thing intermittently. I am now in the habit of making my way around to double check the door because sometimes it will lock and other it wont... but it always unlocks.
