09 Cayenne S oil Drain Plug Torx Stripped
Does anyone have experience on how to remove a stripped drain plug?  The T50 torx head is stripped not the treads.  I assume drill and screw extractor is the way but I thought I would ask.  I knew the torx head wasn't in good shape and should have changed it last time.  Advice to all the aluminum strips easily!
In the 986 Boxster they have the same plug for oil drain as well as manual transmission (different heads but same length and size of  threads).  I stripped the tranny plug.  I used a screw extractor to remove it without a problem.
As Davet18 says, aluminum strips easy.  When you tighten the plug , don't tighten beyond 19 ft/lbs as stripped bolt heads are much easier to deal with than a stripped oil pan, which would be a real nightmare.
I would also recommend replacing the drain plug with the correct sized aluminum hard-anodized magnetic drain plug by LN Engineering.  Current cost is less than $30.
http://lnengineering.com/resources/2014/03/03/billet-aluminum-hard-anodized-magnetic-drain-plug/
Edited by kbrandsma
I removed the drain plug easily by tapping a triple square into the torx recess. No drilling.  Since the aluminum is so soft a little gently tapping and the triple square sets itself securely.  Not the best use of a triple square bit but it worked.
