Driver Door Ajar Warning not working
I noticed that when I don't close my driver door completely, the warning chime does not come on anymore.  Also the interior lights don't come on when I open the driver door.  So my guess is that sensor/button that detects the door opening is stuck in the "door closed" position.  The other doors work fine.
Where is the sensor for the door that detects the door opening?  Is this something I can just clean with WD-40 or do I need to replace some senson?
The sensor is built into the door lock assy. therefor should the door trim, and the inner metal doorpannel on which all parts are mounted, as window regulator, speaker, inner door handles, door lock assy, etc. be removed. Not an easy task conserning some adjustments, but not impossible to do.
