Trying again. Forum was having issues this morning...triple posting and no pic...
Anyway, this is the error code that I got this morning... any thoughts?
Cheers,
TomF
post-63351-0-68755200-1427908011_thumb.p
Edited by Beninki
The knock sensors themselves are not as susceptible to interference, nevertheless it can happen. Most of the time it is a wiring/connector problem, broken wiring, loose connection, short to + or -. Also note damage by rodents.
Thanks. I will check for the code again today and see what comes up. IIRC, if the sensor goes bad, the CEL will come on and that hasn't happened.
Cheers,
TomF
