Hi all,
Hoping for some advice.
The threads on my hub knuckle that the calliper bolts go into are damaged. The calliper bolt continues to turn without tightening. Can this be retapped or a helicoil used? Or, will I be needing a new hub knuckle?
When done properly, helicoil is a good and reliable solution.
