this might be a bit of a noob situation.  my drivers seat doesn't go up and down when i pull up on lever A - also lever A only goes up not down - do i need to do something different before i take it apart?
It took me a year to realize the raise/lower thing is not electric ... since the switch looks just like the switch on my Mercedes which is.
Since it's not electric, it only needs to move one direction to release ... after which you get it raised/lowered manually.
This unless you have the 8-way seats in which case I'm no help.
