So I have Sport Chrono in my 2007 911S.  I thought it was operated through the PCM and could't figure out how to turn it on.  A friend has a 911 with it also and showed me how to do it but when I go to the display on the tach where it should be I have no option for Chrono.  Is there a trick to turning this feature on?  Maybe in the key fob settings?  No clue why I would have it in the car with no access to it.  Thanks for any help.
I might suggest taking a look at the owner's manual.
If I recall it's on the PCM menu (don't recall what section) and is turned on/off via the stalk.
ps. Make sure you have 'Sport Chrono' . . . Do you have the 'wart' on top of your dash board?
