2006 Cayenne S 202 injector code with secondary air code
Live in SC and the temps have dropped 20 deg the last couple of days.  Been around 50 deg in the morning.  Check engine light came on with a 202 injector circuit code along with Secondary Air code.  Is it possible the secondary air caused the 202 injector code?   I am thinking the cold weather may expose an issue with one of my secondary air injectors.  140k and they have never been replaced. no noticeable issues driving.
Update,  cleared code and drove it around the block, no issues.  Parked for the day and came back later, got about a mile out from home and started skipping.  302 code on the same cylinder.  Replaced the coil and all is fine.   Got in this morning, started it up and threw a 202 code(fuel injector out of range) but runs great.   Running great all morning.  Still thinking injector 2 is going bad.
Not suprised about the coils or possible injector.  I have have already had to replace one coil.  If I am not mistaken the injectors and coils are original with 140k miles.
