OEM Rotary Switch to Manually turn on the Cooling Fans
Rotary Switch to Manually Turn on the Cooling Fans Porsche 996/986     So the rotary switch has a fan symbol that lights up the same colour as the rest of the buttons in the car when the headlights are turned on. To turn on the low speed fans, rotate the dial up and the symbol lights up blue. Turn it down for the high speed (and the engine fan as well) and it turns red.    The automatic function of the fans is not affected by this at all. In fact, the indicator lig
