Hi,  I have a 2008 cayenne s with 105k miles.  Started getting p0455 code frequently.  Replaced gas cap, purge valve, diagnostic pump and carbon canister.  Everything is new Porsche part.  Well I smoke tested the system today.  Started with the t connector on vacuum pump-nothing.  Disconnected purge valve and smoked back to carbon canister.  The filter on the carbon canister is smoking.
Question:  can this be the source of the large leak p0455 code?
Thanks, Chuck in Missouri.
  • 4 years later...
The mystery has been solved.  It was the valve cover.  Porsche of Omaha wanted 7700 bucks to replace the injectors and valve covers.
How did he find out it was the valve covers? I thought these have there own stand alone vacuum pumps??
