Has anyone had the same problem with their climate control display, where the segments randomly disappear. If so is there a fix?
Edited by Dukeblue
It seems to be a problem with the temperature - & + buttons. The temperature doesn’t go up and down like it should it seems to jump instead of going up 0.1 0C with each press. This happened just after I cleaned the unit with window cleaner!
Edited by Dukeblue
