Hey guys the AC on the car stopped working and yesterday I hooked up the gauges and there was zero freon in the A/C, so for sure I have a leak. I hooked up my air compressor and I filled the AC with 135lb of air and today I was down to 50lb so I know it has a good size leak. I'm wondering is there a common problem with the AC that I should look at? I'm going to put in a few cans of freon with dye in it to see if I can find the leak.
thanks
2008 S
