Has anyone had experience with the spoiler not retracting smoothly? I ran mine up and down the other day when I was washing it and noticed that it almost acted like there were some bad gears or something in one of the extension tubes.
Any comments would be appreciated.
Sounds like a problem in the tube-in-tube elevator mechanism (all plastic, no gears), try spraying the mechanism with wd40 as well as the hinge mechanism on the spoiler itself. I've had mine apart several times troubleshooting after instillation and subsequent fixed spoiler removal, very quirky peice of equipment.
Manually raise the spoiler and from the top spray some WD-40 down the tubes on each side that house the shafts that support the spoiler. then raise it and lower it manually a few time until the action is smooth.
