Valentine One Hardwire to Homelink
The following procedure was used to hard wire a Valentine 1 detector into my 2006 Cayenne using the Homelink as the power source. Hardware: T-20 Torx head screwdriver (magnetic recommended) T-25 Torx head screwdriver Needlenose Pliers Flat Blade Screwdriver Pocket Knife Electrical Tape Hardwire kit from V1 Multimeter (recommended) Procedure Remove roof console Start by removing the two screws behind the sunglass holder with the T-20 Torx screwdriver: Next, remove the lens over the
Edited by MomentumGuy
  • 4 months later...
there are two red wires, make sure you test it before putting the console back.
The wire you want is the one farther towards the center of the console, i.e., not the one nearer towards the edge.
tmc
  • 3 months later...
tmc
Beautiful, beautiful post! Just finished the install on an '06 CTTS and it was as easy as pie.
Thanks for the efforts behind the post!
I LOVE RENNTECH.ORG!
  • 4 months later...
  • 4 months later...
  • 7 years later...
hi dear,
i've found this topic and i try to clear.
Well
the cable from the chassis isn't complete on my Cay 04 Base. the plug of three wires it's complete, but, the first red isn't under 12v.
Red arrow on mother board isn't under 12v
the plug (white 3 wires) are:
orange 12 v for the  buttons lights led
brown ground
red: 12 v  switch on the homelink
but...
check the serial number before you buy.
the Homelink can be works in Single Code or Rolling Code. Check your Electronic Gate or radiocontrol
my Elvox system  works on 433.92 mhz in rolling code. now isn't listen the new code :(
Francesco.
