Hi Anyone help with this. Come back to my car after a couple of weeks away. Opened the car with the key due to the power saving mode (I believe). The alarm went off which was unusual. My passenger couldn't open the door nor did the window go down. The central locking light stay on when the engine is running and wont disengage/engage to turn off?
A few weeks ago I had a problem with the windows dropping on their own (Ferry's Ghost ?) Is this in anway conected pehaps with the underseat controller. I looked at TSB 6/98 5737 but this looks a mechanical fix to me.
Hi, you didn't post your car year or origin (USA, ROW etc)
When opening the car after it has gone to sleep, you need to get the key into the ignition within 10 seconds to disable the alarm. The Central Locking Light will extinguish if you click the dash tip-switch both ways. The windows may need the 'pinch' limit reset - do this by pressing to close, then press again for about two seconds.
