CD Stuck in the CDR-220
Hello Todd,
Try this :
go in your car but do not switch your ignition on, or even better don't bring your key in the ignition barrel.
Push on the 'CD eject knob' of your radio for 5 sec.
If nothing happens then you keep this eject button pressed and switch the radio on while still pressing the 'CD eject knob'.
Doing this the first command of your radio will be to throw the CD out.
If you do not press this knob then the radio will first 'read' the CD and when the CD is NOK for one or another reason then it will stay in the radio.
If it doesn't work then repeat the whole thing after having disconnected and reconnected the battery.
Success !!
Alfred
Edited by privateselling
  • 14 years later...
