All Activity
This stream auto-updates
  1. Today
  2. Yesterday
  3. What a pain. Let the go down to 30 miles left to empty. Fuel light has been on since the 50 mile mark. The message “consider remaining range” starts popping on and off. Stopped at a gas station I do not like. I put 4 gallons of gas for another 15 miles to go. Restarted the car to go, no change in the display of warning message, low fuel light, and gauge is like o didn’t put 4 gallons in the tank. I have only filled this car once before and had it for a month now. 2009 997.2 C4S.
  4. Last week
  5. It’s works!!! Super!! Thank you very much.
  6. Unbelievable! Thank You!
  7. Try 7032
  8. Hello Loren, looking for a radio code on my recently purchased 986. serial number is: 15007952 type: 4462 CR-220
  9. Try 9853
  10. Hello Loren, I purchased a Porsche Becker CR-2200, I obtained the following information from the service menu: Type: BE4466 Serial Number:X5012006 Could you please help me find the security code? Thank you. Hiroki
  11. I have designed such a 3d part for my 2001 C2. It fit, bench tested great, and worked on the car once. One full open to windows up. One full closed to windows up. Then (printed in polycarbonate) the threads stripped. But, here's the design for anyone interested.
  12. Earlier
  13. Worked! I love u.
  14. CDR-220 24/99 4462 Y5039288 New car for me, making it original...
  15. Side flap threaded insert had split, so the rod was spinning in it at the top most position. The microswitch wouldn't engage, so the clamshell wouldn't close. I made a replacement. https://makerworld.com/en/models/3232512-porsche-996-cabriolet-side-flap-repair-insert#profileId-3661479 https://www.thingiverse.com/thing:7401985 EDIT: With my part made out of polycarbonate and installed, the top opened completely as expected until the windows went up, then closed completely as expected until the windows went up. Then my part failed: threads gone. I sent my design to a shop to make me some out of nylon, PA12, I'll see if they hold up better. Regardless of the stable solution, The top works.
  16. That is an Alpine radio - sorry but my program only does Porsche Becker and Porsche Blaupunkt.
  17. Thanks, it worked. I'm kind of amazed you've been doing this for the community for this long.
  18. Hello Loren, new user here, just bought a 928 and im not having the stereo code please i would really appreciate your help! Stereo CD-2 S/NO PO CD-2 X 08 12927 B 9 08 12927
  19. Try 9639
  20. Hello Loren, I'm the new owner of a 2002 Boxster base and, of course, the radio needs a code that is nowhere in the vehicle. CDR 220 BE4462 Serial 25017119 Thanks in advance for your help.
  21. Hi I too am looking for a radio code. I called Porsche and gave them the VIN and they gave me a code of 5189. The radio doesn't seem to accept it. The serial number on the radio is 25017160. it is a CDR-220. I don't know the history on this car and if or the radio has been swapped. Any help would be appreciated.
  22. Thank you so much, i'll try this code shortly and let you know how it turns out. I really appreciate your help
  23. Try 3090
  24. Thank you so much for all your help.
  25. Loren, I need your help. I have a 2002 Carrera 996, with a Becker CDR-220. I was having some work done and battery was disconnected, here is the information for my radio. Thank you so much for all your help. I forgot to mention, i have a ride out coming up, and i could really use the radio. Becker CDR-220 Type 4462 Serial X5036871
  26. Thanks for looking Loren! Appreciate it.
  27. My program works on Porsche / Becker models. Becker Monza was not a Porsche model.
  1. Load more activity
