All Activity
This stream auto-updates
  1. Past hour
  2. Sound absorber - so if you want to be able have a conversation while you drive I would leave it in place.
  3. Lost Radio Codes DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread.
  4. Yesterday
  5. Turns out it's a 'Butyl Plate'. A butyl plate on an engine cover (or a car hood) is a sound-dampening pad made from synthetic rubber and often backed with aluminum foil. Its primary job is to act as a vibration damper and noise barrier to make the cabin quieter. Learn something new every day... now... to remove it or not..!!??
  6. Could I get a Radio code for my 2001 Boxster radio serial number X5033316 Thank you
  7. As per the title... what's it for? I'm not looking for 'guesses'... i want somebody, if there is anybody, to tell me FACTUALLY the reason for it..? I'm thinking about cutting it out, to get some more engine sound...
  8. Last week
  9. Porsche dropped that part in 2008 so it might be best to find one at a salvage yard. Sorry.
  10. 1998 986. The hp hose connection at the power steering pump continues to leak. I have tried sealing with teflon tape and pipe joint compound. I'm not sure how much torque to put on the nut. Any ideas?
  11. Earlier
  12. Thanks for sharing this. Is there a wiring diagram to check the wiring and pin connections? I am assuming I will be checking the MAF pins and some points in the fuse box.
  13. I'm going to remove and clean the injectors I think
  14. Could be a bad MAF (or wrong MAF) or a bad connection. Check the wiring and pin connections also.
  15. So, after Loren, pointed it out. I reconnected my Durametric today and it did pop up two codes - P0120: porsche fault code 115: MAF below limit & P0107: porsche fault code 229: something about Ambient Pressure Sensor Looked them up and P0107 pointed to pressure in the intake manifold - checked the reading for ambient pressure sensor and it was within range at 1005 hPa (1.005 bar). Started the car and it did not change at all, even when RPM goes up to 3000. Is that normal? I deleted this code and drove around a bit (~4 miles) and rechecked the code did not come back. Measured the readings for Mass Airflow and Hot Film MAF and they are both in the range ~19 kg/h. Still disconnected the MAF and drove and it is little rough when idling but very smooth pickup from stop and NO STALLING". Then, connected the MAF sensor, the pickup is relatively jerky, but did not stall. MAF voltage is 1.2V at <1000RPM and ~3V at 3000 RPM Does it point to faulty MAF?
  16. Also, interestingly, if I just lift my foot off brake and let it roll, before accelerating - it works every time - no stalling.
  17. I bought this car in 2018 with ~30k miles. NO water intrusion since then. If it was there earlier I can't say. Having said that that is quite a few miles without that issue. Still I am curious as to what makes you ask that question. Are you thinking some electronics under the driver seat? Also, I am new to Durametric, and have only run the general scan for faults. Not sure if there is way to scan for individual components (not that I would know which component(s) to scan for in this case)
  18. Are you sure Durametric does not show any pending fault codes? Have you had any water intrusion? Wet carpets? etc.
  19. Hello there, I am new to this forum and may not be listing all the necessary information, so please let me know what other information is necessary to troubleshoot this issue. My 2000 C2 stalls when gassing from stop (esp embarrassing at traffic lights), it has 69K miles on it and I have tried to troubleshoot and replaced several parts but not able to pin-point the source of this issue. Happens to it when it is hot (>180 deg) or cold. It seems to have started after the fuel pump change. The following parts have been changed so far (within last 500 miles); - New fuel pump and fuel filter - New fuel pressure regulator - New MAF - New Throttle body Durametric (Enthusiast version) does not show any error codes. Any thoughts, much appreciated.
  20. Serial # 5009357 - I added the 1 my apologies
  21. It's a 4462 if that makes a difference I did the code 0598 and it just tells me to WAIT
  22. Hello. My 1999 Porsche Boxster battery went dead and now I cannot get my radio to work. I cannot find the radio code in my paperwork. It's a CDR 220 serial #W50091357 Thank you.
  23. WHT 000 324 hexagon head bolt (combi) 6X28 $1.75 each (US MSRP) - 11 required WHT 000 322 hexagon head bolt (combi) M6X12 $1.70 each (US MSRP) - 2 required WHT 000 321 hexagon head bolt (combi) M6X40 $1.70 each (US MSRP) - 3 required
  1. Load more activity
