All Activity
This stream auto-updates
  1. Today
  2. Yesterday
  3. I have designed such a 3d part for my 2001 C2. It fit, bench tested great, and worked on the car once. One full open to windows up. One full closed to windows up. Then (printed in polycarbonate) the threads stripped. But, here's the design for anyone interested.
  4. Last week
  5. Worked! I love u.
  6. Try 5186
  7. CDR-220 24/99 4462 Y5039288 New car for me, making it original...
  8. Side flap threaded insert had split, so the rod was spinning in it at the top most position. The microswitch wouldn't engage, so the clamshell wouldn't close. I made a replacement. https://makerworld.com/en/models/3232512-porsche-996-cabriolet-side-flap-repair-insert#profileId-3661479 https://www.thingiverse.com/thing:7401985 EDIT: With my part made out of polycarbonate and installed, the top opened completely as expected until the windows went up, then closed completely as expected until the windows went up. Then my part failed: threads gone. I sent my design to a shop to make me some out of nylon, PA12, I'll see if they hold up better. Regardless of the stable solution, The top works.
  9. That is an Alpine radio - sorry but my program only does Porsche Becker and Porsche Blaupunkt.
  10. Thanks, it worked. I'm kind of amazed you've been doing this for the community for this long.
  11. Hello Loren, new user here, just bought a 928 and im not having the stereo code please i would really appreciate your help! Stereo CD-2 S/NO PO CD-2 X 08 12927 B 9 08 12927
  12. Try 9321
  13. Try 9639
  14. Hello Loren, I'm the new owner of a 2002 Boxster base and, of course, the radio needs a code that is nowhere in the vehicle. CDR 220 BE4462 Serial 25017119 Thanks in advance for your help.
  15. Hi I too am looking for a radio code. I called Porsche and gave them the VIN and they gave me a code of 5189. The radio doesn't seem to accept it. The serial number on the radio is 25017160. it is a CDR-220. I don't know the history on this car and if or the radio has been swapped. Any help would be appreciated.
  16. Thank you so much, i'll try this code shortly and let you know how it turns out. I really appreciate your help
  17. Try 3090
  18. Earlier
  19. Thank you so much for all your help.
  20. Loren, I need your help. I have a 2002 Carrera 996, with a Becker CDR-220. I was having some work done and battery was disconnected, here is the information for my radio. Thank you so much for all your help. I forgot to mention, i have a ride out coming up, and i could really use the radio. Becker CDR-220 Type 4462 Serial X5036871
  21. Thanks for looking Loren! Appreciate it.
  22. My program works on Porsche / Becker models. Becker Monza was not a Porsche model.
  23. Hello Loren. Was wondering if you could help with this one. I have a Becker Monza. Model: BE 7886 Serial: 55002481 Thanks in advance!
  24. Hi, I have a Porsche 996 from 1997 I think. Could someone please help with the radio code, I've already tried multiple tools online but none of them worked. The radio is a Becker BE4467 CDR-22 with serial number: X5018983. Thanks in advance. Gilles
  25. Hi, I'd really appreciate some help retrieving the radio code for my car. Car: 1999 Boxster Radio: CDR 220 Serial number: X5025716 Thank you for your help!
  26. Lost Radio Codes DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. This topic is closed.
  1. Load more activity
