I have a CAT that seems to be having issues (or maybe the O2 sensor). It trips a CEL once in a while - maybe once a month or two or three. Anyway, after a few trips, it resets and the CEL goes off - until the next time. But I don't want to miss an important (or just another) CEL in the meantime, and the car will be in the shop to fix the offending part soon enough anyway.
So I decided to get a code reader to check the code when it happened, so I don't have to run to the dealer every time. If it's the same code as always, I want to reset it.
So, I got a Cen-Tech 94217 Code Reader at Harbor Freight (http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=94217). This appears to be a rebadged Autel Geniscan GS400 (http://www.auteltech.com/gs400.htm). Everything is the same, right down to the manual.
Now the kicker, it accesses the car, reads the codes and displays them. I had a P0420 code.
BUT, when I try to erase the code, I get an "Erase Failure!" message.
I'm guessing that this is the reader, and not a Porsche specific issue.
Any thoughts?
-td
MY00 C2 Coupe
Appears to be DME 7.2
Edited by td873
You need to make sure you don't have any other fault codes. If you got an aging sensor fault code also then it could be a bad sensor not the cat. If there really are no codes then you may have a bad cat.
