Part Numbers for MO30
First your numbers:
996 333 051 14 -- US M030 Rear Shock
996 343 041 17 -- US M030 Front Shock
MY99 Cab -- 2 wheel drive -- 6 speed RoW Parts:
Front
996 343 041 16 -- Shock
996 343 531 12 -- Coil Spring (color coded Yellow/White)
996 343 701 04 -- Stabilizer (swaybar) (same as US M030)
Rear
996 333 051 13 -- Shock
996 333 531 12 -- Coil Spring (color coded Green/Red)
from VIN --
>>991S6 41090
>>991S6 00548
>>991S6 40407
>>991S6 40432
or
996 333 531 40 -- Coil Spring (color coded Green/Red)
from VIN ---
991S6 41091>>
991S6 00549>>
991S6 40408>>
991S6 40433>>
996 333 105 107 Additional Spring
996 333 701 17 -- Stabilizer (swaybar) (19.6 mm) (same as US M030)
  • 7 months later...
Loren,  can you post the correct part numbers for the Euro RoW MO30 Suspension, front & rear?  I have a 1999 996 Cab C4.  A shop in town said they could probably beat whatever I am getting it for.  Thanks.  -  And GREAT site!!!
Tony
MY99 C4 cab - 6 speed -- RoW M030 (sport suspesion)
Front Springs: 996 343 533 15 (marked Lilac/Orange)
Front Shocks: 996 343 043 13
Front Sway Bar: 996 343 703 02
Rear Shocks: 996 333 051 13
Rear Sway Bar: 996 333 701 17
Rear Springs: 996 333 531 04 (marked Brown/Red) to VIN 991S6 41090; 991S6 00547; 991S6 40407; 991S6 40432
OR
996 333 531 37 (marked Brown/Red) for all numbers higher than above numbers.
Please note these are for a 6 speed. If your car is a Tip them some numbers will change (due to weight differences).
Thanks Loren, my 996 is a 6speed. My VIN number is xxx - I assume this number is higher than the ones you list so I should use the 996 333 531 37 (marked Brown/Red) part number - correct??
Also, the numbers you gave me are the ones for the RoW Sport suspension that lower the car 20mm in the front and 10mm in the rear - correct?
Edited by my996
:unsure: Loren (or anybody) is the RoW M030 suspension a good upgrade for my 01 C4? (I can get a good deal thru SunCoast Porsche.) I just want it down a littel and a little stiffer.
Jim
Yes, but it will lower your car too. Make sure you can live with a car that is 3/4 inch lower in front and 1/2 inch in the rear. It doesn't sound like much but if you already have trouble in some driveways...
Loren or Gert or someone in the know,
I am not sure if I got the correct part numbers. I ordered a RoW M030 suspension kit for my 1999 C4 cab 6 speed. According to Loren, I should have gotten the following part numbers …
for the Rear Springs (996 333 531 37 marked brown and red); and
for the Rear Sway Bar (996 333 701 17).
(By the way, my VIN number is such that it requires the 996 333 531 37 or equivalent not the 996 333 531 04 which would be for lower numbered VIN numbers.)
what I got ..
for the rear springs was 996 333 531 12 (marked in Brown and Red); and
for the rear sway bar I got 996 333 701 19.
When I called the Porsche dealer to see what happened, I was told that what I got are updates from the old part numbers. Loren, Gert or anyone in the know, can you please check and see if I have the correct part numbers. Thanks.
Tony
Loren, can I bother you to check these part numbers? I have an '03 C2 6spd coupe. I'd like to double check the numbers before jumping into the install.
Front:
996 343 531 19 (spring, front, white/green, blue)
996 343 041 21 (damper)
996 343 701 04 (sway, front)
Rear:
996 333 531 26 (spring, rear white/green, blue)
996 333 051 26 (damper)
996 333 701 19 (sway, rear)
996.333.105.03 (bump stops)
Front:
Rear:
According to the parts list those numbers are correct.
Enjoy... :D
There goes my final excuse :)
Slightly off topic, but related. I've seen a couple DIY instructions for suspension R&R on the various sites. Is there an "official" manual you'd recommend for someone doing the job themselves? I'd like to make sure I get the torques right, etc. Also, I'd like something more detailed than "remove the rear carpeting".
  • 10 months later...
geeez Loren - I think I am in trouble. I purchased the ROW M030 "complete" suspension kit from a company in the UK(not Carnewal) and I have a feeling I am not "complete" or even correct :(
COuld you please verify what exactly I received
2003 C2 coupe 6 speed
Shocks 996.343.041.18 (x2) and 996.333.051.22 (x2)
Coils 996.343.531.19 (x2) and 996.333.531.26 (x2)
shocks have green dots. coils have green & white dots next to each other with a brown dot lower down on the coil
Satbilizers 996.343.701.04 and 996.333.701.19
two random pieces that are in pairs that look like they secure the end of the stabilizer bars? 996.343.792.12 and 996.333.792.25
there are two brass colored rings(~2" in diameter) that go with the rear shocks and the only part number they have imprinted on them is 996.3.00 and they are only with the rears, not the fronts.
i can't find any bumpstops or compensation plates - are they supposed to be in the "kit"? if so, do you know the part numbers for these bumpstops & compensation plates(don't even know which thickness i need?)?
here is a pic of my kit:
6c_1_b.JPGd to be in the "kit".
thanks a ton as always
Edited by Lizard1
Front shocks - 996.343.041.18 are for a MY02. Although the parts list says they can be replaced with 996 343 041 21 (for MY03).
Front springs - 996.343.531.19 is correct. They should be marked Green and White.
Rear shocks - 996.333.051.22 are for a MY02 (again). Although the parts list says they can be replaced with 996 343 051 26 (for MY03).
Rear springs - 996.333.531.26 is correct. They should be marked Green and White.
Stabilizer - 996.343.701.04 and 996.333.701.19 (replaces 996 333 701 17) are correct.
996.343.792.12 and 996.333.792.25 are new stabilizer mounts since your new bars are likely larger in diameter.
Bump stops and compensation plates can be reused as they are the same. The kits vary so I've seen some with and some without.
So the only thing I see in question is the shocks. I do not know the difference between the MY02 and MY03 shocks. Perhaps it is just the manufacturer since the parts list says you can use the newer ones on an older car.
Bump stops and compensation plates can be reusedas they are the same. The kits vary so I've seen some with and some without.
Are you sure he doesn't need new rear bumpstops? I'm almost certain the ROW030 comes with new rear bumpstops -- mine did...
first of all - THANKS!
i read in an earlier post in this thread about there being a choice between the compensation plates' size. is it best just to stick with the ones that are already on my car then?
as far as the bumpstops, it was my understanding that they are different. here is a excerpt from the artice on the PCA website about the different suspensions:
"here are standard as well as sport rear bumpstops all of which were measured as shown in Table 5 with the rear sport bumpstop found to be 13mm shorter than the standard version."
i don't know what year these part numbers are from but i included it to show the height difference.
thanks again for any guidance!
thanks again! i feel like an idiot now but just realized that when i ordered this suspension i did not confirm that i needed it for a 6 speed rather than a tip. but my part numbers match up for a 6 speed right??? talk about lucky.....geesh :D
thanks as always - i ordered the bumpstopss from Sunset and am having them expedited from Germany since they're are ZERO available in the US
i'll let you know how the install goes in a couple of weeks :D
I'm trying to order from sunset as well
Loren, can you verify that the part number they gave me at sunset is in fact for my 03 6sp coupe.
000 044 500 27
The kit comes with all that you guys have mentioned right? I have the cheapy oem std suspension now..
thanks in advance
