Will a GT3 Airbox fit on a C4S?
Will this GT3 Airbox fit (and work) in my C4S?
The reason that I am doing this is NOT to try to improve performance. It is to get a Turbo Deck lid and spoiler to fit on my C4S.
It looks like a very similar airbox to the TT, but obviously puts the air into the engine differently.
Here is another GT3 Photo:
Here is my car:
It looks like there might be two problems:
one is the oil filler tube.
The other is the fact that the fuel injector looks canted to the right on my car and it looks like it is headed straight back in the GT3.
Anyone have any comments?
i see you have been trying to do the same task as i have, TT spoiler on the c4s.  any luck so far??
Yes and no.
I got it on the car and it fits on the car just fine. When you close it the two struts that are the hydraulic device that push up the wing (at 75 mph) hit the airbox on the right side and the smog pump on the left side.
Moving the smog pump is easy. I found a bracket that goes with the EVO intake that moves the smog pump. I couldn't figure out if a GT3 or turbo have a smog pump, but that bracket might work also.
Getting the airbox out of the way is tough. I think that I am going to buy an extra airbox and cut the corner off of it in such a way that I can still seal it up.
Then there are three other problems:
-The fan seems like it is going to rub on the intake rubber tube.
-I will need to cover the hole that was the Turbo intake hole.
-I will need to make a new hole for the C4S intake.
Edited by navin in KC
ha, congrats on the progress.
how much did you get the TT lid for? and is it worth it?  how about an aftermarket one instead?
I got it for $2050, and will probably end up spending at least another $300 making it work.
I think it was best for me because it was already the right color and I like the fact that the wing/spoiler goes up and down.
navin
If the only fit issue is the hydraulics, then this could be good news for any C4S owner looking for a different decklid. I'd have to believe then that the factory Turbo Aerokit rear wing would fit (fixed wing) as well as any aftermarket fixed rear wing. The TechArt Street GT S rear wing I have sold (pending) would also fit. Wow.
