Faiz Sulaiman
Everything posted by Faiz Sulaiman
  1. hi everyone, im being haunted with TPMS now. first problem is left side appear req??? if u check in tyre pressure, meter keep pop out TPC inactive, system learning. so below is what i have done; -check battery life, FR 0 month. i changed FR wheel sensor -after changed the sensor, i run about 5km (TPC inactive still pop out) -i diagnosed again n check battery life, RR 0 month then.. ****! -i dont believe the scanner, so i do system adaptation -problem still same, i then swap rear tyre. -scanner still show RR 0 month, i then swap TPMS rear antena -problem still same..now i dont know what to do. im wondering how TPMS get wheel electronic ID? i noticed 1 thing, first time i check the ID *******217 at FL, then today 217 at RL! anyone get the clue? i have running the car more than 20km but it still learning.
  2. hi magnum08, any update about ur car? im also having issue with fault 2250, valve operating time exceeded..now it cant be calibrated bcos of this fault, rear are higher than front
  3. problem solved..abs pump replaced and noticed grounding at pump area was taken out. tq everyone
  4. nope, n this 2009 model dont have brake light switch like previous cayenne..correct me if im wrong.
  5. hi 993GT2. did u solve the problem? im facing a same problem, fault present with my scanner are P0129 - lost communication with brake system control module and P0503 - vehicle speed sensor A intermittent. now car cannot start, PRESS BRAKE PEDAL pop up..any idea what to to do?
