martsink
    Toronto
    2000 Boxster S
martsink's Achievements
  1. I seem to have the same problem. Sounds like something completely loose in the tank. I can shake the car side to side and hear it. Using chassis ears the noise is most pronounced on the hump in the trunk where the gas tank sits. Any ideas?
  2. Hi Loren, Here are my radio details: Type: 4362 Serial: X5017102 Thank you! Vlad
  3. Found the issue. Had to top up power steering fluid. I guess the noise was coming from the pump.
  4. Hey Guys, I finally got around to fixing the cam issues (dislodged freeze plug) that i suffered the first time started the car. This time around this are going much better, but there a weird noise coming from around the intake/throttle body. Its not constant, seems to cycle every 5 seconds or so. In the video below you can hear the noise starting at round 18 seconds when I rev the engine, and then it gets pretty evident again around 35 seconds. Any thoughts? Other than the noise, the car is running pretty smoothly with no codes I have a durametric unit, if there's anything I can check
