Click here to Donate
IanT
  • Content Count
    3
Everything posted by IanT
  1. Passenger door window not dropping down and central locking light on and beeping when locked. This was on 2002 S and if either inner door handle or outer door handle operate ok then it probably is the microswitch in the non operational handle In this case both were not working and this points to the door lock mechanism which has several electrical and mechanical functions Lock replaced and everything now working correctly you do not have to remove outer handle to install
  2. I did replace the CPS but as an Electrical Engineer do not hold much faith in a part that works on cold start and even eventually on warm starts. As a matter of interest the tach moves only very slightly on my 1998 and the same is true of my wife’s 2002 S neither goes to 400 rpm as some suggest. I guess my view is the CPS is ok unless it will not start at all as in my case it must have been ok as it sends a signal to the CPU
  3. My 1998 Boxster suddenly had hot start issues where if left in the sun here in Texas for a few hours would then crank but not fire unless you kept cranking and pressed the throttle. No issues when starting cold. It had thrown some evap leak codes a few times and a secondary AI once but nothing consistent and would also suffer from idle issues if hot start was hard. Having read many threads I decided that it was not fuel pressure related as in my experience fuel pumps either work or they do not and the same applies to the associated relay. I read someone blocked off the valve under the lhs air intake plenum and when I did this the hot start problem disappeared but gave other idle issues. I decided to replace this valve and in the process also decided to clean the throttle body and iacv when I discovered oil in the aos and j tube the aos was replaced 3 years ago. Having replaced the valve and the aos the car appears to be running better than ever. I had no white smoke issues or oil cap pressure test problems and the old valve was in the closed position when I removed it so that may not have been an issue. This whole situation had gone on for many weeks and also gave air leak codes in both banks but using a smoke generator revealed no issues.
