LT996TT
Everything posted by LT996TT
  1. HI, I cant get any power to the driver's seat on my 2004 996 Turbo. I have checked the fuses and they look ok. I have also replaced the control module and still can't get any movement. I am thinking the power harness connector is broken. How would i check this? Are these available for purchase? Any ideas on how to fix? I do not want to have to replace the entire passenger wiring harness. Surely there is a cheap repair method as water gets into the cabin and corrodes the plugs in the CAB versions. Help pls....
  2. How did you go sten? I am having issues getting power to the driver's seat control module. DO you know if these ca be repaired? Can i simply run another power cable from the fuse box to the control module? I can't find a diagram either. I think it may be part of the passenger wiring harness which is like 10K! All other control units are working so maybe its the power connector in the seat. Are these able to be purchased?
