tr8or24
Everything posted by tr8or24
  1. goggots300, was wondering if you ever cleared this problem up? I havinga similiar issue with my 2006 955 V6 base. cluster reads (D) for every gear and have to change gears manually for the transmission to properly function. Thank You ahead of help.
  2. Hey, i'm new to the forums, i came across you post above, i also have a similar question with regards to the battery being disconnected and reconnected. Only in my case the car sat for about 2 years with a disconnected dead battery. i have replaced the dead battery with a brand new one. The second pane glass of the panoramic roof during that time, was left open about and inch or so. The roof has never worked whatsoever in my hands. I've replaced the Roof control switch 2 times with a new switch and a used one, also reused the original with no action whatsoever from any of the Roof parts. The fuses i have replaced with new ones. The Roof motors show no sign of function whatsoever, as if they aren't there. The question i have for you is, were you able to eventually remedy your issues you mentioned? Regarding the sunroof not working on your P!g were the symptoms the same or similar? Thank You
