Ed Borden
Everything posted by Ed Borden
  1. Loren - Thank You Very Much... The code worked and the radio is starting to come alive !!! I have an issue maybe you could help me with... The car I recently purchased is a 2004 Boxster and someone before me had put an aftermarket radio in the car. In doing so, they cut the speaker plug completely out and spliced in a different plug to fit the aftermarket radio. The only thing nice is that while cutting a number of wires from the power supply plug, they left the plug behind so I was able to solder the wires they cut and get that plug back to operational. I'd like to get a factory plug for the Speakers and splice them back in as well. Do you know where I could locate said plug ? Also, is there a way to know what the original radio was that came in the car when it was new ? It's not that big of deal but not knowing these cars that well, I can't tell if the CDR-220 is a 2004 thing or if it really should be the CDR-22 And two more things, if you could help with them - I'm not sure about the antenna as to what the plug end coming from the car is supposed to look like as well, I have a loose Yellow plug that appears to be part of the car wiring for the radio (Or at least that area) and while it looks to be factory, I don't see what it plugs into, currently it's not fitting any of the spots on the back of the CDR-220 radio that I'm working with. Again, I appreciate your speediness with getting me a working code for the radio that I bought for getting the car back to looking like it should and look forward to your reply - Thanks, Ed
  2. Just received a used CDR-220 and would like to get the code for it: Serial #: X5038255
