PAULSPEED
Everything posted by PAULSPEED
  1. Thank you for your response. There is a box under the drivers seat. All connections were connected and there was no blank connector. I did not look under the passenger seat.
  2. Trying to help a friend with his 1988 911 Carrera. Could not locate the OBD connector. Any help? This could be a european car. The Vin number on the door was scratched off and there is no vin number on the top of the dash. His DMV vin number is WPOEB0917JS161141. Car has not run in about 6 years. Paul
  3. The passenger part number is 3D1-837-016-C. Suset Porsche wants 175 dollars. When I replaced the driver's door about 5 years ago, the part was made in Poland if I remember right. About a two hour job for me.
  4. Have not checked the crank case vacuum. Will take it to dealer. The AOS is original. No squealing noises. Yes, it is parked on an incline. It is there on start up and then goes away. It then comes back on deacceleration when the car is warmed up. Thank you for your reply.
  5. I replaced the serpentine belt. I replaced the boot between the air cleaner and the throttle body but forgot to tighten the hose clamps. Drove the car over 100 miles and it started to smoke. Tighten the hose clamps and the smoke went away. A couple of days later the smoke is back. i think I might need to replace the air/oli separator. Maybe it just needs to be drained. Thank you for responding to my HELP issue.
  6. Took me 4 hours to get the water pump out and 6 hours to put it in. Good thing I don’t make a living fixing Porches.
  7. Wow. 7.5 foot pounds. I expected alot higher. Thank you Loran
  8. I read that the seven bolts that hold the water pump on are torque to 7 foot pounds. Is this right? 2006 997s tiptronic USA
  9. My spring broke last week. I will order the part from Sunset Porsche.
  10. I have a friend with this problem. A common problem is the drive shaft bearing. From whit I have read, You need to buy a $800 drive shaft from Sunset Porsche. The bearing is not sold by itself. Paul
  11. You should look for used cats. There are used Porsche junk yard in Los Angles and Arkansas. I am sure there must be Porsche junkyards in Germany. Paul
  12. Maybe your nav CD needs to be reloaded. Do you have any repair shops to go to check if you have any error codes. Paul
  13. So it is the gauge on the left. Looks like a large water container filer next to the needle. I will look at the radiators. I will also get a price for new radiators. I heard that you need a negative suction pump to fill it. I also heard that you can just fill it and keep adding fluid for a while. Thanks for all the replies. Paul
  14. Went for a spirited drive up to the top of Mount Hamilton. The car water temperature is normal at 210F. Near the top of the mountain I was looking at 240F. Is this too hot. I have cleaned out the radiators a few years ago. The car has 130,000 miles on it. I blew up the motor at Buttonwillow Race track. I had a new factory rebuilt motor installed around 60,000 miles. Should a 70,000 motor take these 240F temperatures. Luckie for me it was only near the top of the mountain. Thanks for any replies.
  15. Just tried the key in the ignition switch and unlock the doors. Key works fine know. Thank you for your post.
  16. Thank you for your reply. The oil sender is broken. He bought a new one for over $140 his costs. He is going to lift the car and then lower the motor. He hopes he can get his hands up on top of the motor to remove and install the oil sender. Wish there was a easier way to do this. Paul
  17. The problem with the car is when you turn on the ignition (engine off) the oil pressure gauge goes to max pressure. We know it is not the sender because we disconnected both wires and still the same problem. We also know that it is not the gauge, tried another and the same problem. So most likely it is a grounded wire somewhere between the gauge and the sender. I also disconnected all wires to the engine so the short is not on the engine. Most German cars usually have the same kinds of problems so if someone else has had this the short may be in the same place. Thanks in advance for any help. This is my friends explanation on what is wrong with the car. Thanks for any replies. Paul
  18. My friend is having problems with a 1997 993. When you turn on the key, the warning lights stay on and the pressure switch shows high. He has replaced the instrument cluster and replaced the oil pressure switch and this still has not fixed the problem. He thinks that a wire is being pinched to cause this. Has anyone ever have this problem? Thanks again for any responses. Paul
  19. Anyone have the wiring diagram for a 1997 993? Loran does not have one. Thanks, Paul
  20. I just broke another one. There is not much you can do to improve the life of the links. The banjo bolt produces a lot of vertical stress. The threads on the nuts wear out. I have to dig under my car but I think the banjo bolt sheared at the threads. Yes I have a bigger a thicker sway bar to reduce roll. Paul
  21. You may want to get a new one from the salvage yard. http://www.oklahomaforeign.com/ Paul
  22. The tires shoud be 19 and not 18. See if you can test drive another similar car. Paul
  23. You may be having a problem with the car running hot. Push the wing button next time you drive. Paul
