am993
    Toronto (Canada)
    2010 Carrera C2
  • Future cars
    Any, as long as it is a Porsche
    993, Boxster
am993's Achievements
  1. Sounds like carbon build up. Mine had similar symptoms, but only if the car had been sitting for a few days. I ran a full tank of gas with a bottle of Techron Concentrate Plus, followed by an oil change and voila, problem solved.
  2. +1 for a CV joint coming off the bell housing side. Look under your car at the back, center left and center right: if it is the case, one CV joint's gearbox end is most likely resting on the respective side's lower control arm. 15 minutes fix and you are on your way.
  3. You may be in terested in this thread: http://forums.rennlist.com/rennforums/rennlist-canada/537094-on-the-road-again.html Jaak bought a Boxster S with a blown engine and had it rebuilt in Toronto over the winter. You may want to chat with him on actual cost of rebuilding, ...
  4. I would strongly recommend AUTOWERKS in Woodbridge, ON (www.euautowerks.com). Or if you want to source a used engine, you can try Nineapart (Porsche only wrecking yard) in Tottenham, ON (www.nineapart.com) Good luck.
  5. Similar thing happened to me last week-end, with the turning signal. I picked-up a complete switch unit (gently used) for $30.00 on eBay. It's in the mail and will install it when it arrives.
