JD Sphynx
    TX
    09 Porsche Cayenne s
  • Future cars
    Nissan Skyline
    none
JD Sphynx's Achievements
  1. So in this case I plug and un plug check for loose wires ?
  2. Hi Loren! It was such a pleasure meeting you, and thank you for getting back to me. I wanted to ask where I might find those modules, and if you happen to have any diagrams available, that would be fantastic! I'm fairly new to using Cayenne at the moment everything on my cluster is fine I don’t have any fault messages or codes showing up, which is great! However, I’m having a little trouble with the lever for changing gears when its on manual it just wont work it doesn’t seem to work when I push it up or down. The tiptronic switch on the steering wheel works perfectly, though! I tested the solenoid actuator, and it’s functioning well, but I’m planning to swap it out with the new one I just purchased. I truly appreciate your help with this! Thanks so much!!
  3. Hello everyone, pleasure to meet you all. I’m experiencing a similar issue that started with my battery running low, which then triggered the 4x4 warning message on the screen. I replaced the battery, but I have not yet replaced the transfer case solenoid actuator (part number PAB341601KT1). I also noticed that on my cluster display, the gear indicator (D1, D2, D3, etc.) no longer shows correctly. The SUV runs fine overall, and I haven’t experienced problems with the gear lever getting stuck, the key being affected (locked)or going in to limp mode, However, the display is inaccurate — for example, when I shift into Reverse, it still shows “D” instead of “R.” When I shift into **Park, it continues to display “D” until I turn off the SUV, at which point it resets to “P.” I scanned the vehicle and retrieved code 1316 – Tiptronic Switch using my X-Tool scanner. I can clear the code, but it returns again after driving. so you only see the D on the display. From my side, I plan to replace the transfer case solenoid actuator soon. In the meantime, I’d like to ask: What solutions have you found for this issue on your end? please keep me posted
