zman1858
Everything posted by zman1858
  1. Porsche stop making the old style cable and wants me to pay $300.00-$400.00 in parts for the door to accept the new style cable... I don't think so. I cut the new style to fit the door but it didn't work. Does anyone know where I can find the old style...Sun doesn't have any, local dealer doesn't, and LA Dismantler is looking. The drawing is the end that goes into the door handle. Oklahoma Foreign said they would sell me one for,,,ready....$40.00 and LA Dismantler said $30.00. Come on...new was $7.00. I hung up on them. Still looking if anyone can help.
  2. Mine happen one day when it was very cold...stayed that way until summer time showed up and cluster is back to normal....wasn't dead pixels. It just fixed itself.
  3. Mine has been doing it for about 3 years at start-up in the mornings....By the time I drive 2-3 blocks...stops
  4. Mine started the same issue, what is the repair. I have a 1998 Boxster. It was pretty cold the night before minr started. Will it get worse.
  5. it was leather. the leather is worn out. i pulled the leather off and it was tucked under the silver...i'm doing a carbon fiber overlay so it will be easier if i can take it apart.
  6. I'm redoing my shifter knob. The silver part feels like it should come off but won't move any more than shown. No screws can bee seen from the inside. What does it take to remove the silver part. Also,,what will polish and make the silver look new. Thanks
  7. i jacked up car and can rock the tire from side to side. It moves about 1/8 inch on both sides. Really rough ride at all speeds on roads with any bumps or pot holes. Front end feels like it is going to fall off. Any ideas....possible bushings or controls arms....80,000 miles...thanks
  8. I have same issues. i jacked up car and can rock the tire from side to side. It moves about 1/8 inch on both sides. Really rough ride at all speeds on roads with any bumps or pot holes. Front end feels like it is going to fall off. Any ideas....possible bushings or controls arms....thanks
  9. Water pump changed in a little over 4 hours....a few breaks in there,,,didn't lower the engine. To All those that do this, remember to bleed the lines...drove down the road and warning light blinking....bleed the lines and all was fine
  10. Which bolts should I remove to lower the engine to make replacing water pump easy...please refer to diagram and bolt numbers..Thanks
  11. working now.....400.00 for brain....175.00 for key fob...240.00 to program...
  12. If you click on the central lock on dash and it works and the remote lock work, then I feel the the imobli is fine, just had to change mine....the interior lights were flashing on and off, the remote lock won't work and central lock on dash do nothing...I would look else where
  13. The dealer here has one for 391.00...not bad....they are 60 miles away....I have roadside asst....they love me....Called them and said I need a tow from Pensacola Fl to Mobile AL....they were no at first...explained that it was about 1 hour away....at lease I gat a laugh from that....it will done Saturday. Dealer said that the key fob sometimes won't program, which means another 150.00...love the dealer... I will have drain holes for the next rain storm
  14. Thanks...I will order one from Pel Parts tomorrow, 400.00... I have a friend that should have a programmer, if not, 100.00 - 150.00 more to program. not bad. You can bet there will be some drain holes in the floor board now...heheh
  15. Do you think that it will be better to buy one from Pel Parts and have it programmed. I figure, $400.00 plus programming, a new unit would be better than a used one and the part in the trunk should be fine.......any thoughts....thanks for the fast reply
  16. This about the post about water damage, can someone please read the last post I did on this topic. I need to order a part and need an answer to decide what to order...thanks so much.....link to the water damage question below http://www.renntech.org/forums/index.php?/topic/35757-98-boxster-wont-crank/
  17. From what I have read, the unit under the driver, the M535 unit is what got wet. Is this the the immobilizer. And where is the brain. I can get a M535 from Pel Parts for 400.00. Will it need to be programmed. Will the car run before it is programmed. I hate to spend 600.00 - 700.00 for a M535 and a brain and a key fob if I don't have to. Am I missing something here. Need a little help to try and save some money.....Thanks
  18. Thanks for the input....time to look for a new brain....off to see the wiz of OZ....I will be drilling holes...nice idea....
  19. dried the hell oout of it with hairdryer.....nothing the onlt fuse I found was in the main fuse box and the one one the unit...anywhere to look...does the dealer have to program new one
  20. 98 boxster..the other day the interior lights were flashing and a loud humming from inside the car. Pulled over and shut it off and it won't crank back up.. After a hour, it started back up and ran fine for 5 days, Then it did the same thing again. Replaced the ignition switch....no cranking....looking under the driver seat, it was wet. The first time it won't crank, it rained that day. It also rain very hard the second time. I took the M535 brain box apart and it didn't look pretty. That was were the humming was coming from. The central lock light on the dash won't light up, the passager door won't lock. I clean the electronic board with contact cleaner and still nothing. When you turn the key, nothing is going to the starter. All other electrical things work fine. tried jump starting, nothing. Will the M535 keep the car from cranking. Help.....
  21. Key fob hasn't work in forever....when you lock it with the key, it beep twice, the clamshell is off the hinges because the cable broke but it's been that way for 1 year, the micro there isn't the issue,,, can a micro in the door cause it not to lock
  22. I had it read at AutoZone and no fault code on the alarm system
  23. I know the issue is with the central locking system. it will not light up on the dask when I click the button. The remote doesn't work, when I lock the car, you can hear it lock and then it unlocks. After about 3 tries, the driver door will lock but nothing else will. The passenger door and the gas flap won't lock. Can it be a mirco switch somewhere or will it be the cpu under the seat since the switch for the central locking won't do anything....I have check the fuse under the seat (good) no water under the seat and carpet is dry, .....any ideas
  24. daily driven....changed plugs, runs better...a leak in the catalytic converter appeared from no where. There wasn't one there before....very strange. I can feel the air when I put my hand up to it. If I run straight pipes and remove the cat's. what do I do with wires from the O sensors
