turro
Everything posted by turro
  1. Hallo the code 030 means that you have the sport suspension installed. It's harder and the car is lower(10mm). The Paket sport technik is an option the combines the 030 sport suspension 17" wheels and the traction control. All these options could be ordered separately, except the sport suspension. If you wanted that suspension, you had to order paket sport technik. I think from model year 1999 the sport suspension became a separate option. Option 490 is the sound package. Ordering that option you got additional speakers in the doors(bass boxes) and an amp in the front trunk, for a better sound. C16? Must be something special for the UK. But I don't know what is part of that pack. In germany the wasn't such an potion available. Perhaps it's the ac and the electrical mirrors. Perhaps someone else can help with that one. Turro
  2. It is necessary to switch the headlights on to use the headlight washers. you have to push the stalk that operates the front glass washers forward and hold it, until the washing is finished.
  3. Here are the pics of the tool.
  4. Ronbonner, a PCM can not be updated to software 5.43 using the 8bit nav computer. You have to have the 16bit. So it's possible that the nav display was changed on warranty after may 2001 and the new one got version 5.43. Or, when you are not the first owner of the car, the previous owner changed to 16bit, updated the system, but took the 16bit out before the sale. But as I mentioned before, it is not possible to use opel cds dated 2002 or newer without the 16bit nav computer.
  5. valcax, on the left and right side of the 8bit computer in your car, there are two plastic caps. You have to remove them. It should go with your fingernails. Behind the caps there are two holes on each side of the computer. The tool has to be pushed inside the two holes. The tools look like the letter C, it unlocks the computer so that you can pull it out. I will make a picture of the tool and the nav computer with the caps removed.
  6. Ronbonner, that problem was described by other porsche users in my community. When not all 8 cds of the package, sold with the 16bit computer, are used to update the navi, the opel cds won't work. There is a file on one of the cds(I don't remember which) that is necessary to get the opel cds work. Are you sure that you have a 16bit nav computer? When your car was delivered after, I think May 2001, you should have one. The 2004 version should work when it is for the opel systems I mentioned above.
  7. Yes you can buy it at your Porsche dealer. The part number is 996.642.122.03. There should be no problem changing the nav computer. You just need a tool to get it out. It is a Blaupunkt tool, also used to remove standard Blaupunkt radios. When you get it out pull out the plugs and insert them in the 16bit computer. That's all. You perhaps will have to reenter the code after switching on the navigation. The code is sold together wit the new 16bit computer.
  8. Looks like you are right. They seem to be from 2004. I have to ask my dealer for details. The Opel CD work on 8bit and 16bit, but it's depending on the year of the cd. Opel Cds dated till 2001 can be used in the 8bit computer, from then on Opel(siemens) changed their nav computers(as Porsche did) to 16bit, and the following cds work only on 16bit computers. But when there are 2004 cds from Porsche, I see no need to buy Opel Cds, O.K. they are a little bit cheaper. As I mentioned above, I have to ask my dealer if he sells 2004 nav cds for germany. The lates info from Porsche was that the PCM1 is no longer supported with new cds, latest pack 2002. Perhaps something changed. Or the cds in the auction are labeled 2004 and contain data from 2002, no one knows untill you put the cd in the nav and see the database.
  9. I don't know how Porsche handles it in Spain. But in Germany there was the problem, that Porsche did not update the PCM1 cds. The latest were from 2002 and needed the 16bit computer. They only offered cds for the PCM2 with a updated database. That's why people found out that Opel cds work as well in the PCM1. I don't know about a cd for germany sold by Porsche with 2004 database. But when Porsche sells the 16bit update in Spain with 2004 database cds, then you would not need to buy Opel cds, that would solve the problem with the newest porsche cds not beeing available. Beside that, I think that the 2004 cds update the system in the same way the 2002 do, perhaps the software version is even newer.
  10. I don't know for which country you need nav cds. But for germany you buy the opel navteq cd, that is used in tehe Opel Zafira or Vectra. The system is also made by Siemens. It's called NCDR 1100/1500/2013/2015. The Opel CD only works if you have the newest porsche software installed in your PCM. Press the AC button on the PCM and then hold the right button for about 3 sec. The display shows the version. In germany Porsche sells the PCM 16bit update for 1500 EUR together with a software pack incuding 8 CDS for Europe, they are from 2002. You have to put all of these in your new Nav computer to get the complete update. After updating, the software should be version 5.43. Then just insert the Opel CD for your country dated 2005 and you have the newest road database, but without the Porsche service centers. Instead the Opel service centers are displayed. I have checked it out with the Opel CD for germany dated 2004 and it works. The only problem I see with this update is the high price, especially for the software. The software alone costs 400 EUR and you need it just once(to update the system). If you have additional questions I will try to help.
  11. Yes that's right. Only the nav unit has to be replaced. With the 16bit nav unit you can update your software to version 5.43. With this version, you are able to use opel nav cds(in germany) and they are always updated. Newest version ist 2005 for germany. Price is about 1000 EUR.
  12. Hallo do you perhaps know if the pcm1 has the possibility to change the brightness of the display. I only found the contrast option in the BC section. My display is very dark, I can hardly see something. Perhaps a combination of buttons has to by pushed to access the brightness option, do you know something about this? Thank you turro
  13. I have a problem with the diagnosis of my pcm1 over the diagnosis plug under the steering wheel. I have the pcm1 wiring diagram, and it says that the diagnosis wire from the pcm1 goes to the point vs90, can somebody perhaps tell me where to find that point. The diagnosis wire from the instrument cluster and the airbags should also go to that point. Is it perhaps somewhere on the relais support? The wire has the color orange/blue, when it comes out of the pcm1. thank you for your help. turro
  14. Yes in the hi-fi option, there are two speakers on each side under the cover, instead of only one in the base option.
  15. Hallo don't you have any ideas?
  16. When you ordered the hardtop you got the rear window defroster with it, but no heated and electrically adjustable mirrors, these had to be ordered separatly. The radio is a US type radio.
  17. In Germany the headlight washers were offered for the boxster since 1996. I think the defrost button is missing because the owner has not ordered electrical adjustable mirrors for his car. When you missed that in the first years of the boxster production in germany, you got only manually adjustable mirrors without heating, and without the button.
  18. Hallo i would like to install a cell phone antenna in my 1998 boxster. In the 98 boxster it was placed above the windshield, but from my01(i think so) it is somewhere in the front trunk, to the right of the battery, where the fresh air filter is mounted, right? Does someone of you have pics what it looks like? The numbers of the parts i need to buy, were also great. I don't want to drill holes into the body of my car when it is possible to place the antenna near the filter. Do you have prices for the parts? Thanks for your help turro
  19. The manual says the Becker Mexico works with the Becker 2660 and another one, but I forgot the number, have to look it up. I the manual of the radio is written, that you have to plug in the wires of the changer into the radio, and that is all. The radio should recognize the changer, I have to push a button an the radio to change the source that plays the music. One is the radio(works fine), when I push it twice the md is activated(works also fine) and the third time pushing the button should change to the cdc, but the radio is activated instead. So perhaps my radio is broken. But as I mentioned before the changer has power, because I can take the magazine out by pushing the button inside the changer. I don't know what to do, when I buy a new Becker radio, or a new Porsche MDR32(identical with the Becker MD, but the price in germany is 1200 EUR) I have no garanty that it will work, so I have to use my old CR-21, or build in the PCM :)
  20. Hallo is there a part number for the wires that belong to the PCM 1. I read an article on the internet how to retrofit a PCM 1 in a Boxster. It seems to be easy, but only with the harness. On the photo attached to the article was the harness, but I don't know if the person made it on her own, or bought it from Porsche. Thanks Turro
  21. I called the Becker Service Hotline, and they told me, that it is not possible to install any Becker Radio to the Porsche CD changers like the CDC-3. Even if the changer is made by Becker and the label says BE 2660. I do not belive this, because he also said that it isn't possible to install a Silverstone 2660 to a factory Porsche Radio like the CR-21 etc. I thought that it's no problem to install a Silverstone to a Porsche radio. Has anyone in this forum a Becker radio and a porsche CDC-3 changer installed?
  22. Thanks for the help. I ran the wires inside the car and put everything back together. But the CDC is not working.. I can insert the magazine into the changer, but my radio does not recognize the changer. I have a Becker Mexico MD radio. I changed the radio back to the original Porsche Radio and the Changer works fine. So what is the problem? I have bought the original porsche cd installation kit, with the original porsche wire. Both Radios are made by Becker, also the changer, in the manual of my becker mexico is written that it supports the becker silverstone 2600 or 2660, I don't remember exactly. The Silverstone is the same as the CDC-3, right? I don't have an idea how to solve the problem, perhaps you can help me. Thank you Turro
  23. Hallo is there a TSB available for the retrofit of a original CDC-3 Porsche CD-Changer? I have bought the Porsche harness for the changer and would like to know how to install it into the car. Thank you for Your help Turro
  24. Hallo, can you tell me what part this is: 996.555.181.13 A11. It should be an interior part from the 996, but is it from the cabrio, coupe or targa? Thanks for your help Turro
