p0rsch3
Everything posted by p0rsch3
  1. I've used it now for 1yr+ and about 8k miles. No issues at all, love it as much now as the day I installed it. I can see the point of not using in inclement weather since the filter is open directly below the engine lid vents, so there is potential for water to enter... but it would probably have to be a lot of water since the oiled filter should displace things like drips. what would be ideal is to design a top shield for the filter, maybe out of CF. i'm going to talk to my buddy who makes custom-fabricated race car parts (does a lot of CF work, hand-made my 996 console lid out of CF and it looks SICK!) - Let you know if that turns out. I think with a small cover it would resolve any potential inclement weather issues. Sure, the "sock" will repell light water. But wouldn't a CF cover look nicer and be more effective? :) Doesn't K&N supply a water repelling cover that goes over the filter now? I don't know what they call it, I always called it the water boot, I have one on my RX8. I've seen them on 996s before.
  2. Yeah I'm in Beverly Hills just south of you. My friend who does the CF work is down in Long Beach / Pedro area. Were also going to be working on designing a flow-through race exhaust for the N/A 996 that offers a happy medium between muffler bypass pipes and regular mufflers. If you're interested let me know, we may need a few test cars for dyno runs.
  3. I paid $0 - My friend who owns the shop owed me a favor (I fixed his porn-ridden virus-infected shop computer.. lol). Eric at bumperplugs has one of the lowest rates I've seen. It is not easy laying down quality paint over the OEM rubberized finish, and he guarantees his work.
  4. No problem- Brian is a really cool guy. I had the console painted black by a local body shop, yep mine used to be "ugly gray" too .. lol. you can get the best work on a black painted console from Eric at www.bumperplugs.com - Eric has very good prices on painting, and is a forum sponsor over at www.6speedonline.com
  5. Here you go: btw if you want one made, go to http://www.afterhourscompositeworks.com, call number on bottom of page and ask for Brian Kono (owner). Tell him Kurt sent you. If you send him your lid and back piece he can do the same type of work, probably around $500. Guy is a true artist, I can't believe he does this by hand.
  6. I've used it now for 1yr+ and about 8k miles. No issues at all, love it as much now as the day I installed it. I can see the point of not using in inclement weather since the filter is open directly below the engine lid vents, so there is potential for water to enter... but it would probably have to be a lot of water since the oiled filter should displace things like drips. what would be ideal is to design a top shield for the filter, maybe out of CF. i'm going to talk to my buddy who makes custom-fabricated race car parts (does a lot of CF work, hand-made my 996 console lid out of CF and it looks SICK!) - Let you know if that turns out. I think with a small cover it would resolve any potential inclement weather issues.
  7. update- I noticed that the noise only occurs when the car is warmed up. If I floor it while not completely up to temp, there is no noise. Any thoughts?
  8. do you happen to know the wire color? I did not cut off my plugs, I simply tapped into the wires with scotch-locks. Seemed more sane to do it that way. :)
  9. Thanks again Loren. It could be the wire is somehow touching something and setting off the alarm, will have a look at it and post my findings. The engineer at Durametric (his name is "Duram" if you can believe it.. heh) is a really nice guy, i'm going to let him know about the incorrect code.
  10. Thanks Loren- I cannot erase alarm faults with duramteric, but they do show count increments. I replaced the compartment sensor 42 and 60 have been there for a long time so i'm confident that is not it. so 54 is the radio and not tilt sensor eh? so much for Durametric accuracy. I do have an aftermarket NAV / DVD unit (Kenwood) - Odd that I have had it installed for some time before the false alarms started. Should the wire for the radio alarm be grounded to body, attached to the kenwood chassis or simply taped up and tucked away? I will pull out the radio and have a look.
  11. hmm- I wonder why I would be logging a tilt sensor error if I don't have one?
  12. I looked by the battery and there is only the alarm siren. no other wires present, empty plugs, sensors, etc. odd???
  13. So my alarm has been randomly going off when locked and sitting idle. Happens mostly when the tempurature changes throughout the day. I bought a Durametric scanner to try and track down the offending sensor, and initally thought it was the interior sensor. I replaced it, and it is still falsing. Now when I look at the durametric I saw that error code 54 for the tilt sensor had incremented by one count, and noted with "not in idle position" Does my '02 US car have a tilt sensor and where is it located?
  14. where is the tilt sensor located on an 02 996 coupe? I think mine is causing same problem.
  15. awesome- thank you for your input. how is the height measured for the mount?
  16. I'm in process of tracking down an odd thump when shifting from 1st to 2nd under hard accell. Feels like an engine mount or something along those lines, so putting it up on my buddy's lift this next weekend. (this issue is different than the buzzing vibration noise in my other thread- trying to find that too!) I am not familiar with the mounts on a 996 engine and tiptronic trans- how does one check to see if the mounts are bad? Is changing them pretty straight-forward? I've done this on other cars, just not a pcar. Any insight is appreciated. I searched the site but did not find any decent info.
  17. i have an almost identical problem. I thought it was mufflers so changed them but it's still there. it does indeed only make the vibrating rattle when nder hard accell taking off in 1st. if I punch it in any other gear or lightly rev in neutral, no noise. did you find out if it was the cats? how do you check if your cats are bad?
  18. ditto - mine as well. it's annoying but I've learned to come to a complete stop before manually dropping to 1st.
  19. Yep, that was my first suspicion as well- but after having changed the mufflers and disassembling the bumper / heat shields for a thorough inspection it did not cure the problem. The thing that makes it so darn perplexing is it only does this under full throttle in 1st. So maybe.. if the mounts are not solid the drivetrain is flexing from torque and causing something to touch / vibrate? Is it tough to replace engine and tranny mounts on a (tiptronic) pcar? Have done this on other cars but not on a Porsche.
  20. Not yet, but I think I may need to replace one of them- I have a definite 'thump' when hitting the 1-2 shift hard, which feels / sounds mount-related. could the vibrating sound be related?
  21. worth considering, but sounds kind of dangerous to test like this- is there a DIY here on removing belt and location of tensioner pulley?
  22. Yep, I had the entire back bumper and shields off yesterday when we did the muffler swap. Nothing loose, broken or (from what I could see) rubbing. I also did some slight shield tweaking just to be sure, because this was my initial thought as well. The odd thing is, if it were simply a resonant vibration it should also do it when revving in neutral or hard accell in other gears correct? It only makes the sound when accellerating hard from a stop or slow roll with wide open throttle in 1st. If I do the same in 2nd gear from stop or slow roll, no noise.
  23. That is the metric airflow discombobulator. If you remove or clean it you will lose 5whp. I fixed mine by removing entire intake and replacing with a KN intake. One of my favorite mods.
