mudman2
Everything posted by mudman2
  1. Present when idling ? Present when Rolling in neutral ? Can you hear it outside ? Sparrows nests ?
  2. Ever thought how you avoided that prior to back up cameras ? I would never trust them. Sorry for your hardship, but pep boys sell a wireless camera for nothing
  3. They sell thru channels, "Cartronics" seems to have a good reputation
  4. From what I know if you interrupt the PCM during updates in any way there is a danger of bricking it from which there is no return, thats why the manual says to run the engine while updating or put the battery on charge. You have little option not but to get a PIWIS hooked up to it to see the error codes it throws. In parallel, I would contact Becker US to see if they can service it for you
  5. You don't say what year but i would change the battery right now, all sorts of funny things start to happen when battery is bad
  6. Fascinating, so there is no transmission control unit, no electronic valves controlled by the DME / Transmission control system, no PSM or Anti Lock Brakes etc on the V6. Is the transmission not made by Asian either on the V6 ? Wow you live and learn :notworthy:
  7. You really are underestimating the computing power in the car, disable it and it will not run, do what your planning and it will not run. Good Luck You should have gotten an S
  8. As i recall you need to remove the PCM trim to see the screws
  9. Pretty sure the transmission control unit would kill that plan of action since the shaft would be turning out of control
  10. I must not be understanding something here. The subject of this thread relates to the Carden Shaft, there is only 1 on the cayenne it drives the rear wheels. If its gone there can be no drive. If your talking about another drive shaft please be more specific
  11. its the main front to rear drive shaft so no
  12. no you lose all drive to the rear
  13. You have to remove the Aircon controller/display
  14. if the side walls on you rear tires are compromised it will feel strange and noisy, like a shimy. see if there is any variability in the noise/vibration try to describe if so
  15. to soon for the shaft I think the replacements for the original seem to last longer Any noise associated with the vibration ? Feel it thru the steering wheel ? Rear wheel or tire issue, kerbed it at all ?
  16. The transmission control unit should not be effected since the pump seal it not really part of the geartrain itself. Its the seal right not the pump itself, that would be VERY unusual
  17. its for all 2003-2006, all models, the warranty is 4 years or 50K miles on the COILS from the date of replacement so long as the vehicle was under 100K when the coils were replaced. It also allows for $ reimbursement if you paid for them to be replaced so long as you have receipts I will post the pdf Monday edit : seems to be for 04 and higher part numbers
  18. there is a reason that the Pmera is $110k its the touch screen nav
  19. Waste of time just get the Vertex and move on, its happened to us all
  20. The only problem I know of is with the upper shock member
